Shaft break
Tool
Tool set
Shaft Break
Detailing
To insert a shaft break:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
Shaft Diameter
Specify the diameter of the shaft break object
Width of Break
Specify the width of the shaft break object
Configuration
Select Solid or Hollow
Wall Thickness
For hollow shaft break configurations, indicate the thickness of the shaft wall
Structural shapes and details
